  • Replies 33
All, perhaps to quell speculation here.
The survey is resultant from the Coroner issuing a 'Prevention of Future Deaths' report to the industry / HSE and the chaps Father who is driving a campaign to 'consider' a possible engineering solution / control.
There is no underlying proposal to ban 'toppers'...or certainly not as far as we are aware.
Cheers all,
Paul
Fixing a nose guard to a saw is clearly the idea of the moronic, chainsaws are dangerous that's just a fact and i believe they have enough safety features if used correctly.
Cheers all,
Paul
Hi Paul whilst my heart goes out to the families and friends of those who lost loved one in these tragic events I strongly feel and engineering soloution/control is the wrong road to be taking.
Having some insight to one of those who lost his life recently I feel training and also those that employ needing to look at supervision to prevent further deaths as being more useful to prevent further deaths.
Hill Marc, I do acknowledge your comments here and encourage you to complete the questionnaire.
Thanks
Paul
A chainsaw cannot be made safe, s##t bust. They are used to cut things much more resilient than what the human body is constructed off. They are a necessary evil as it were to carry out work on trees. Our work is on trees and every single one is different and x ray vision does not exist to see inside what we cut on the ground or in the tree, therefore accidents will happen. Whether that's pure bad luck or user error is something to be decided after the fact. Everyone is guilty at some point of bad practice or laziness, some of us more than others granted.
I feel that spending two weeks on a course and being qualified to "crack on" is not right, the irata system does not allow this, why does arb? Some of us are lucky enough to be tutored and mentored from day dot however the training system doesn't make this mandatory in my mind it should and I have added this to the site.
Ok survey completed, why hasn't hse or AA thought that if you had a anti kickback tip guard you would be in danger of forward leaning timber doing a "widow maker" and killing the climber?
Cheers all,
Paul
Thanks Paul. I'll douse my flaming torch and put my pitchfork away.
Maybe there should be an electronic trigger on the handle behind the chainbrake, a bit like the magic eye on grinders.
Sure you could tape it up if you were of a mind to do it, but more responsible companies could ensure that doesn't happen.
Bar tip guard will only stop kick back, it will not stop using them one handed and cutting other arm or body.
Also chain technology has improved along way and maybe improved more to stop kick back.
Exactly. If your needing to do a dog-tooth whilst climbing you'd need to call up a different saw. A lot of people wouldn't bother and just do a standard felling cut increasing the risk of an accident.
Sent from my iPad using Arbtalk
