Stein 3001 here. Nice simple to use device. This is what I like about it the most. You can instruct anyone to use it in 2 minutes flat. Thats the most important thing to me as a freelancer as I have different groundsmen nearly every day. If I had the same groundsman ever day then I might consider something more complex. I can probably count on one hand the amount of times I have ever needed winching capabilities though in 20 years of tree work.
I remember when you got that Jonny....Still going strong.Seen your posts of it lifting/holding on tip tie for ease of cutting.... Stein 3001 here at Premier and a heavier duty Polish version of a Hobbes type block.
This is what I use ,it's like a Hobbs but a bit easier to set up and use as you can have more extreme rope angles going in to the drum. It's no gcrs in terms of lifting speed but lifts and lowers whilst not being to over complicated.ImageUploadedByArbtalk1487662825.089062.jpg.7f1e875bfd0af6b72fc46b806bb3fe6d.jpg http://shop.freeworker.com/special-winch.html
Also a 3001 for jobs where no pretensioning is necessary and a Portawrap for light rigging.
This is what I use ,it's like a Hobbs but a bit easier to set up and use as you can have more extreme rope angles going in to the drum. It's no gcrs in terms of lifting speed but lifts and lowers whilst not being to over complicated.[ATTACH]217135[/ATTACH] http://shop.freeworker.com/special-winch.html
That's the one we have..Well made.Does the job.
