advice needed for removing wood and brash from steep garden
flatyre
Petrol engined portable winch, e.g. PCW5000 or similar.
How many trees in total? Do you intend chipping and if so where? garden or driveway. You say they're 14' wide and the gates are under 3' wide, do you intend snedding the branches off in the garden then dragging the stems and brash up separately?
It's obviously possible but not easy to suggest a method without a bit more info. Obviously if you could get the entire tree up to a driveway or yard in one go that would be the quickest, then decide where you go from there.
  • Replies 64
as said earlier in the thread. the biggest problem is boots on the ground. the same tonnage 0f timber and brash will need to go out of the garden so if you drag winch or arb trolley/wheelbarrow it out. how about pricing in some repair work re turfing or re seeding as the damage is going to happen
unless you get a crane that is.:001_tt2:
Old school but we used to lift the turf first and put it back after.
Beat me to it. Hire a micro digger(ideally with a thumb if available) and a muck truck scrape off turfs carefully with grading bucket- have the mother of all fires- use digger to spread the ash (over the site of the tree stumps?) then relay the turf gentally tamping with the grading bucket to bed them in and level them. The timber could then be shifted with the muck truck.
