Just wondered what the largest hiab some one had mounted on a defender. I would like to make a dedicated hiab defender which would be capable of lifting my 1 ton predator over walls and fence at 6m min and lifting my Splitta 400 off my trailer and running it off the hydraulic pto. Any thoughts?
how much payload would the defender have as a chassis cab?
I think you would need a crane around the 8tm mark to comfortably lift 1 ton at 6m reach. A crane of that size would be just under a ton dry weight, +60 odd litres of hydraulic oil, then the subframe to mount it on.
The other point to consider the stability when it comes to loler testing having quite a light base vehicle.
Had similar thought a while back and basically it came down to how heavy the crane was as to what reach verses lift could be achieved without overloading the land-rover, never got further than it being an idea but 1 ton at 6m is quite a bit don't think my big botex is even rated at that!
Sent from my D5803 using Arbtalk mobile app
Look through the hiab and palfinger websites it lists the ton/meter and the operating weight
You will get a higher ton/meter over weight ratio if you look for the models with manual extensions
I think you will struggle to get a worthwhile lift off a landrover base.
If you are going ahead is it worth considering an old cherry picker, it would give you the hydruilics and posably some additional legs, both might be mot exempt but I don't think you can tow with it if using an mot exemption.
  monkeybusiness said:
I think the size/weight of subframe and stabilisers required will be your biggest problem.
If the vehicle is only carrying the crane and if the crane had 4 legs to displace the lifting pressures the vehicle load capacity is all the chassis will need to carry.........
I'm pretty sure that even if you found a crane and base light enough, a landy will be too light a base vehicle to get a stable lift of that weight at that distance, so you will never get it LOLER'd.
Think what he ment is the legs and frame will eat into the weight that the vehicle can legally carry not leaving a lot for the crane itself, during work it's not a problem as with my landy picker the vehicle is almost just dangling under the sub frame.
Read more
