55 minutes ago, Johnsond said:
I’m just curious and in no way contradicting what you are saying but how are the profits currently being made within the wind industry any different or less  attractive to corporations than the profits being made by say nuclear energy providers??. I have been involved in the offshore side of things with the wind energy industry and have seen firsthand the absolute free for all cash cow that this has become for predominantly overseas companies. Regarding the solar energy/storage set up you mentioned what may I ask was the installation cost and the projected break even point, and does this provide you with all the power you require on a day to day basis Ive a neighbour up here in Aberdeenshire looking to put in a system that’s costing him around 15k he estimates 8 years to break even and is only putting it up as his air source heat pump system  is proving to be horrendously expensive to run.
If he is spending £15,000 to save nearly two thousand per year that sounds like a decent investment.  I would do that if I could.  Actually, I would look at the possibility of doing some work myself to reduce cost.  But when you think many people spend £15,000 on a car which is a terrible investment you could argue.
Big capital builds, like HS2, Nuclear power stations, offshore wind farms as well as petroleum/natural gas exploitation favour big business, in the form of corporatocracy, a sort of monopoly caused by the limited number of organisations with the ability to fund and organise the work with government collusion, whereas an individual can make the decision to buy electricity storage, PV panels, even possibly a wind turbine and get a return on investment.
Okay so the Chinese firms that make the equipment are big businesses but because there is competition  the prices are reasonable.  We know from HS2 where costs are not controlled by competition leading to massive price over running.
Yes it is a dreadful shame that British companies could not compete in the market because Thatcher felt we could live off the backs of our finacial sector, big mistake IMO. We had been in general decline since 1918 and paying for loans from america in the war years was the clincher. We never developed a business philosophy to replace the colonial era.
My system paid for itself in 10 years and because of the FIT subsequent payments have paid for the battery £3400) and additional 1.8kW PV (800) but I did a lot of the mounting myself with salvaged material. I buy 450kWh from the grid in winter but self sufficient mid March to mid October. I heat with a lot of "free" wood.
My daughter's system is more typical, 2 strings one SE one SW giving 6kW installed power running into a 5kWhybrid inverter and 10kWh LiPo battery plus a Zappi car charger cost £12k, I think the firm made about £3k profit over cost of equipment, scaffolding and 3 man days installation by a very competent roofer and similar electrician.. Yesterday produced 32kWh and no grid electricity bought since March, including charging the car. If she can use all the predicted 5MWh of electricity it will produce that is worth £1750, else she will receive 15p/kWh for export which will reduce the return somewhat. Current production is exceeding prediction. If she plays the game she can make far more out of the battery by dumping it to the grid between 16:00 and 19:00 then recharging at off peak if necessary for a margin of 32p/kWh. Which can make the battery more sense than PV panels.
Where it gets interesting is when you combine a (bigger) battery with an electric heating system and a low off peak tariff. I'll be sticking with wood for my heating.
BTW Aberdeenshire will benefit from longer summer daylight but considerable worse outside temperature. Often when people find heat pumps expensive it is because of poor installation. A heat pump benefits from being able to utilise very low (~30C)  flow temperature. Underfloor heating is ideal. Where radiators are used often there is not enough heat exchange surface, so return flow is not cold enough and hence the heat pump has to boost to a higher temperature, reducing COP ( the amount of heat you get out per kWh put in). Ideal for new build but tricky for retrofit.
New build property and incorporated from day one. The facts and figures you posted are very interesting. If I had a spare chunk of cash I’d more than likely try to go that route myself and or a small wind turbine
He’s an agricultural building fabricator and erector by trade and I think that price is with him doing much for the work himself, he’s lucky in-as much as he’s on the family farm so can set up the panel array away from house and at the optimal bearing. As I’ve just stated if money  was no concern I’d probably be heading that route. I’m currently paying average £150 a month plus oil for the heating (rural so no gas )whereas he was on £400 but that covered everything. Luckily the wood burning stove is the primary source of heat for us 90% of the time and that’s fed exclusively with waste from milling.
If he's got the space, did he not make a clanger by not putting in a ground source heat pump, thought they were always cheaper to run? And also solar and cables whilst the place was getting built?
Do you know how the prices add up?
With ground mount there is no scaffold cost and that adds £1500 down here. Even a top grade inverter is no more than £2500 for 5kW and a cheap chinese hybrid much less. My panels were around £500/kW and if you can use a qualified electrician for the connection but to get the export money you need an MCS certified installer in order to get the certificate the electric company will require.
🤷‍♂️I guess at the time he thought not.
No it was just a chat we were having whilst I was up collecting some brackets he’d knocked up,  it’s not a small property by any standards but the cost and break even forecast were all he mentioned.
No wonder there's a labour shortage, they're all driving driverless busses! (2 staff on each one!)
