That's a good lump of oak it's lifting.
Yeah think its approx 34-36" at felling cut not much taper, 10-11' long seemd ok with it :) have had to empty hiab trailer for this week and had a few lumps like that to shift :)
Need some wider pallet forks tbh
You can pick them masseys up for 2-3k there good tractor for loading, you won't do mush digging with it though the hydraulics on mine are bit juddery
That's not bad at all, just want it for loading containers and trailers with chip and mulch, back actor will get very little use but might be handy occasionally
Sent from my D5803 using Arbtalk mobile app
A teleporter has more reach and 4wd yes but if constantly loading you keep needing to re set the wheels to straight! Unlike on these
They also chew the crap out the ground if your back nd forth over the same bit a lot.
