tricks for removal of rust and grim from fuel tank?
Suffolk-Matt
Grinders metal tank is awful inside, Ive got the tank off the machine.
Soaked it overnight with some detergent which has bundged most of the residue but im left with a rust like scale on the inside.
I tryed putting a few old nuts and bolts and giving a shake, which loosened a little.
any magic tricks?:thumbup1:
Take it and get it bead or sand blasted, or, you only need a small DIY type blaster, a full on hydrovane unit will be too much.
Rinse and dry then lacquer the inside if you are particularly keen.
Sealey Sb993 Shot Grit Sand Blast B...
Edit
You can get a sand blast pressure washer attachment as well
Edited by treequip
Oxalic acid. You can (or could) buy it on ebay in powder form. Mixed with water to make a solution and left to soak it eats rust, leaving clean albeit discoloured steel.
Here:
http://www.ebay.co.uk/itm/1-KG-Oxalic-Acid-Hull-Deck-GRP-Cleaner-Rust-remover-/222155639950?hash=item33b9820c8e:g:YewAAOSwsFpWR6vn
Edited by GreenGui
I use a big bag of oddball ba nuts ( about 300 ) and some diesel for this, follow the intructions in the Vid.
Bob.
[ame]
[/ame]
