looking into treating myself to one what are peoples views on them ive heard good reviews so far :001_smile:
chears in advance jayy
have you used x/antal rings? if not it's probably worth starting with them before buying the aerial brake, like the aerial brake they move the friction into the tree but in a more manageable way.
The aerial brake is a nice idea and it would have it's uses now and again for certain jobs/staff but overall a pulley or block in the tree combined with a Port a wrap/bollard on the ground is still the best method for lowering branches and timber.
  • Replies 34
what edwood said, ill use the tail of my climb line for those little bitties too. but I have become a convert to the ariel rigging. mainly the Rig n Wrench. The Rig n Wrench takes is god for 30 lbs to 250. for 250 - 500 I double whip it or span rig it. I don't even pull the porty out the truck for most jobs. The AFB is definitely on my wish list at the moment. The Rig N Wrench is nice because it allows the ground guy to pull with their full weight on the piece, thats something you can't do with the porta wrap or tree friction or the aft, the rope comes back to you easy too. for the smaller pieces you don't even need anyone on the rope.
a mini portawrap is fine for self lowering from the tree.Best used with a swiveling attachment point .Easily adjustable for different weights and can be locked off if required
Just be aware that the rope will want to hockle up (think that's the word)
I havent used this method while climbing though only from a basket
the nice thing about the AFB is that its a square bollard so pulling the rope back up to you after lowering there is less friction and you can get the end back with no problem.
with the portawrap you will have to flick all the holding wraps off to get the rope back.You can do this up to 5 metres away.Usually i will remove all the rope from the device though so it can cool down a bit between jobs.
Obviously much easier to do this from a basket than as a climber
should also point out that a portawrap used from the tree without a swiveling attachment point will suck big time as it allows the rope to cross over itself a bit to easily
