The replacement bridges come with the red stiching on one side only, as obviously you need to thread it through and then tie your own knot.
I wouldn't worry about it
  • Replies 25
Tommy_B a loler inspector cant inspect a knott that has not been tied at the factory so should always untie any treemotion bridge that does not have the red stiching intact. Better having to retie a knott that get a loler fail due to said knott!
Then how could they pass a friction cord if they can't trust the user to tie a knot!?!?
Surely a simple overhand knot doesn't need untieing?
Even the most pedant of pedants can see if it has been done correctly. Now if my LOLER inspector failed a harness on that reason then I would be using some one else.
Agreed
Jobsworths out there
Tbh I would just re stitch it if I lolered it
When I fit a new bridge I use it and load it then stitch it
I can see your logic but there is no way it happens in practice :001_smile:
I wouldn't necessarily fail a piece of kit just because I couldn't untie a knot that had been loaded beyond being able to be reasonably undo it.
[ATTACH]201052[/ATTACH]
Not tried myself but could be worth trying.
Interesting idea, but I can't see how you would get it on without messing about with red stitching though.
Edited by Mat
