cheers ill prob get that one
how do you find it in the cut ?
Great cut on it. I've got a 200t (although underpowered and needs attention) a husky 540 and a echo 280t as well as the 2511. Only use the husky occasionally on dismantles the 2511 gets more use than the rest by far!
Sent from my SM-G930F using Arbtalk mobile app
What file is best used with the Suigi chain? I love my 2511 it's great with the Suigi combo - thanks to Rob D for supplying!
I'm using a stihl file, not sure if oregon etc make them that small? Seems to do the job ok
I've flung 3 chains on the Sugi bar in the last two days. Never had this problem before. Correct tension each time.
A friend of mine keeps chucking chains on his sigihara bar too
That doesn't sound good - and this is with the 2511? I've been using on the ground with a MS192 and had no issues... But I don't expect I use it as much as you fellows.
