Blanking off the egr valve
Maxnaggle
  • Replies 42
My landcruiser had a blocked egr valve. Dealer said he cleaned it but after I check he hadnt. Months later recall and replacement injectors, then after 6 months, back smokey and no power. Jeep had no ommh until 2000 revs.
After dropping jeep into various garages, I was told needed all 4 injectors replacing, egr, and possibly a new engine.
Decided nothing to loose, so cut a small piece of steel and placed it on the block before egr.
Within minutes of starting up, smoke was less, and within a day, all the blue, black and white smoke diminished.
Jeep is way better, mpg up, power etc.
Im not a fan of the egr set up; and seeing the gunk which is like grease, assures me that the set up is far from ideal.
Hi mate how old your Toyota thanks Jon
With newer stuff, you might get an fault code thrown at you if you block the egr valve. So it could be that yours is blocked or something? It's literally a plate that goes between the valve and a return pipe from the turbo (?)
I bought mine off of eBay for £4
Yeah gets blocked, it did it before and we just cleaned and freed it up, but keeps getting coked up!!
