  • Replies 20
Looks like a good size and still able to chip whilst on the trailer, albeit a bit of a lift.
Balance looks forward of the front wheel, what's the weight on the drawbar?
I think loading brush into that whilst it was on the trailer at that height would get pretty old pretty quickly. Plus because it hasn't got a bottom stop bar and its above 600 mm (I think that's the limit) above the ground there might be h&s implications.
Just my thoughts mind.
[attach]196801[/attach]
this was on ebay a while back, bit bulkier than purpose made, but plenty around
Unbolt the ramp and turn the chipper around! And you're ready to go. Must be able to get a decent 3 year old one for £1k.
You see i like to chip with chipper on trailer.
Plant trailers have a 6 fr drawbar, your shoots in the middle of the machine so 7 ft or so before the tailgate of the truck.... Then another 8ft to hit the head board!
I use a gd105 so a 4 ft drawbar better then the plant trailer. Also i can throw logs down the side of the chipper too.
I was just looking at these small trailers as the gd105 can go behind a 4x4 ;)
Fair comment, I've certainly never tried it and don't know the rules regarding stop bar.
To my mind one takes a tracked chipper to site when it is not possible to get the truck to the work, otherwise take a tow behind but if you only have one chipper...
Still looks like the drawbar weight may exceed 100kg.
it sits foarward as the trailer was built around a tw150 not a jensen a530,the 150 rides lower lower so the hopper is lower over the tail gate ,it worked fine for me with no issues ,
Yup i had no issues with it either
