Running an old saw
case mx270
I still run a Husky xp281, worst thing about it is starting it, it is a brute, needs a decompressor on it. Either that or I am being a girl.
Check that your starter rope spool hasn't split, the one I had nearly had me handing in my man membership card until I found out that this was the problem and the rope was binding on itself.
  • Replies 40
Cheers for that, although I did take the spark plug out and it pulled over no probs, bit of a rough test but I had to check.
They are bitches to pull over, you either give it 100% commitment or that starter handle just pulls itself through those tender hands of yours:thumbdown:
They have big compression, a small starter spool and a set ignition timing meaning no girly starting retarded ignition timing like the modern machines:lol:
Best option - make sure it is set up well and starts on 2-3 pulls!
Try a 298XP and the 181/281 doesn't seem quite that bad:001_rolleyes:
ms200t- will stick with these as long as pos,
044 -used daily, cant fault it,
088 -still going strong,
056 (1980) had a new carb, still in use
my mid size planking mill has a Danarm 171ss (1974) I have several spare saws for parts.
newer saws have come and gone in the meantime!
all of these are easy to work on, spares available and simple (like their owner)
Today we were talking at work about the problems people are having with new saws such as auto tune , with this in mind is finding and running a older saw such as a StihL 029 or a husky 350 a good option ? Also for a older saw how long would parts be available to keep the saw running ? The guy I was with has just had his saws nicked and he was looking to restore his husky 55 to use instead of buy a new saw.
The 300 series Husqvarna's are not a bad compromise with anti vibe and less hassle to keep in good running order than some newer ones iv found..as long as the carb to cylinder upgrade has been done. A 351 is not common but is the mag /alloy cace rather than the plastic one on the 350…although the 350 is not a dog by any means. Its not a clamshell due to having a alloy base that the cylinder bolts to . I have a soft spot for late 200 series Husqvarna, 254 and 262 are in the arsenal.Have a Dolmar 109 and a 115i…thats a brill saw at 3.75hp and 52cc..light and short boded, cock on with 15 inch bar. Currently the two saws i tend to pick up to use are a Ms 260 and Ms 361. The Ms 260 has grown on me and the Ms 361 is bit of a revaluation for me. Caused me to look much closer at Stihl saws in the 2002-2011 age with the old carbs. Anyhow there a few personal likes ..but it of corse will come down to personal taste.
254,262,266,268,272.281 288, 2101 are all cracking saws imo,. but im just an old school reprobate lol
I keep a 254,262 and 288 for when I do go out on track, the blokes always comment on the 262 being heavy compared to the MS261 they normally use but I've never weighed it compared with a MS 361 which would be a modern equivalent I think.
