I need a ifor williams tipper ram re sealing but this has a stage or more than normal so needs to be a specialist.
Where should i go?
Chris I would give IW a call and see if they could supply the seals if I was you , its not a big job to change them yourself. Most of the hydraulic shops will give you Rohypnol prior invoicing so take the KY with you if you do decide to let them repair it :thumbdown:.
Bob
Bob
Im not sure how many rams are std with the ifor williams, but this is an iforwilliams ram inside another ram with 1 or 2 stages more for a higher tip angle
D & a hydraulics in hull top bloke does some very big rams. Alot cheaper than most spots local to us as it turns out most places take there rams to him anyway then add there bit on.
