has anyone experience in this or similar on a compact tractor??? Ive watched youtube videos of them in action and Im not massively impressed. how would you rate them against a stihl 81r or similar? I like the idea of holding the height perfect but the finish seems to be poor
Power Arms
[ame]
[/ame]
Used one on a ford 1910 compact tractor on the estate where I was working. Not great results. Very dependent on perfectly smooth ground. Every hollow or lump in ground was amplified by length of arm especially on balloon turf saver tyres. Clean cutting edge though I'd have to go over it twice as some light twigs would be brushed flat and then spring back again afterwards.
Ended up using stihl hs85 for faster better cutting.
Gimmick rather than time saver
Shaun
cant beat experience! theres one in killarney, 3 hours eachway to see it. I think Ill be saving the diesel.... it would probably work with the multi blade thing but it would be getting very dear
I use a Slanetrac 180 finger bar on the bobcat Skidsteer, it's grand on beech avenues and the like, but still needs 2 runs to get a reasonable finish, but it is fast . Great for getting hedges back in order, a quick run of a lad with a pole cutter to tidy up for a fine finish,
