Husky 390xp vs 395xp
MrNick
They are quite similar in specs on paper so what would make you choose one over the other?
Im lucky as I have both . Both ported as well . In real world terms the 395 is the stronger . Old school saw but if it aint broke ..... The 390 runs 28" 3/8 and the 395 runs 36" .404 .
Hi
As per Stubby - the 390 has inboard clutch whilst 395 outboard more desirable for milling (mentioned just in case ST is watching :blushing: )
AFAIK they both port well, the 395 carb is slighty limiting. 390 supplied as .058 gauge whilst 395 is .063 - is that right Stubby? somewhat envious you have both!
N
Edited by NFG
I have a 385xp (predecessor to the 390xp) on 36", I've also used a 395xp a fair few times. I prefer the 385/390, which also shares a lot of parts with the 372, so spares are readily available. I also prefer an inboard clutch, as you don't need a piston stop to change the sprocket or bearings. It doesn't affect the handling of the saw that much, despite what a Norwegian ex-serviceman might protest :lol::biggrin:
