Just wondering how many people have had success using a helicoil type of repair on a chainsaw plug thread?
Ive used then on larger machines without problem but ive heard they arent the best solution and that something like a time sert should be used instead.
I think also on an old 026 but I cant remember tbh:laugh1:
I've given one a go (helicoil) today on a T540xp after one of the lads thought it best to insert the plug from the off with a combi spanner because it was too hot! Lucky it was our saw and not a customers as a new pot would have been on order!
I will be giving it a good testing before its put to use again up a tree.
Have done many heli coils, the key is to get a genuine heli coil tool, not these cheap re coil tools, you must also get the tap dead straight, hold the tap in a pillar drill and turn by hand to keep the tap straight, never turn the tool backwards, use a tag break off tool. If fitted correctly they are stronger than the original thread.
I'm pretty sure I screwed the thread in my 540 while taking the plug out multiple times to sort out an oiling problem.
It's been a temperamental pos since.
Used both helicoil and inserts, good results on both but the quality and straightness of the new cut thread is important with both methods!
I posted pics on my "what's on your bench" thread if any one is interested!
Helicoils are great, I've fixed loads of damaged threads with them, including spark plug holes. Depending on how badly they have been damaged I have also got away with cleaning them up with just the tap.
Hi
I have done a helicoil repair to an alloy car engine cylinder head some years ago, worked fine, can't see why it wouldnt work on a chainsaw head
N
Spudulike has done it on my 395xp and it's been perfect since.
That was a carbide steel one after the aluminium one popped but that was more to do with the receiving thread not being good.
