Waterproof jacket
magwick
  • Replies 107
  • 3 weeks later...
Seems to be lots if threads about waterproof jackets atm.
I remember watching a program called tomorrow's world. They had this magical material called goretex that repelled water but allowed sweat out! Surely someone can make a jacket out of it, it's hardly rocket science, or is it!
Goretex only works in a dry atmosphere.
Your body creates heat on the inside, high air pressure, and this easily pushes moisture out into the low pressure dry atmosphere outside.
Al Gore designed the fabric for high altitude mountaineering.
Here in Britain, the atmosphere is similar inside the jacket to outside. Therefore, a breathable membrane cannot work.
It's the same reason that fishermen don't wear breathable wet gear.
Today was lashing down in Coventry. Wore an endura base layer and tShirt. It got wet but I stayed warm all day, until I finished. Then changed to a dry tShirt. Enjoyed the staying warm part, didn't enjoy the slippery Lombardy poles
Endura base layer £29
