Trailer towing weights.
Alycidon
Currently I run a Defender and and two IFW trailers both rated at 2700 kgs. I have and use a tacho but have no need of operating centre, 6 week checks etc. I do have to abide by drivers hours but thats it.
I am looking at a bigger trailer to take more bags of logs out at a go as I sometimes go 30 miles out, taking 3 drops would be more economical than 2 drops. I also pick up 2 tonnes of wood pellets 3 or 4 times a year, that I think takes me just over 2700 on the IFW GD85.
So if I upgrade to a 3500 kg trailer which the Defender can pull then would that take me into the realms of operating centre etc. I have been though the CPC requirements in detail with Vosa, that drives around the weight of the towing vehicle so no change.
Think uprating would be fine other than some difficulty getting a 4m trailer into some places but one of the 2700kgs is 3m so that would do.
Thanks for your thoughts,
A
I got pulled last night and was told that I needed a tacho because of the plated weight of my vehicle and trailer. Not the fact that I had any weight on the trailer or vehicle.
Also I would need an operating Licence as well as I get a "reward" out of selling my logs as in hire or reward.
Edited by Paper Rustler
Also, i believe, if your unladen weight is under 3.5 tonne, you work to GB domestic rules, not EU rules, and as long as you drive for less than 4 hours a day, no rules apply.
Exemptions to the GB domestic rules
The GB Domestic rules don’t apply if you:
drive for less than 4 hours in any day
drive off-road or on private roads during duty time
drive a vehicle used by the armed forces, police or fire brigade
are dealing with an emergency, eg major disruption to public services or danger to life
If you are on Hire and reward then you do, I got pulled off the M6 on a Police check three years ago. There is a loophole taking plant to site and the driver using it, if within 30 miles of base then no tacho but if the driver drops the gear and goes or others use the gear then its Tacho.
If your max all up train weight exceeds 3.5t then its tacho, so towing vech + trailer + max cargo weight. In theory something like a BMW 7 series which weighs a lot could only pull a trailer about the size of a wheel barrow without needing a tacho.
A
