Yesterday all our machines had to have full throttle starts, chipper overheated 5 times, in the end the saws wouldn't restart, and no shade to put them in!
Hi EDDY sounds great just too hot to work EDDY IN full safety gear so down tools off to the ice cream van 🍦🍦🍦🍦🍦🍦🍦🍦🍦thanks John 👍
  • Replies 38
Pfft I'd be lucky, our trousers are class 2's as well!
So , just to be clear when you say " leaving the decomp in " you are using it ? ( as in is venting and out is sealing )
I assume he meant "leaving it out" (closed) = not using it?
Edited by SawTroll
Thanks Barrie; looks like that's probably the answer to my question.
Do I take it also that you consider Aspen (shameless plug) less susceptible to temperature extremes?
Hi,
Many users have reported that Aspen2 works better in saws prone to hot restart problems.
I can only think this is because Aspen does not contain any solvents and so evaporates at a slower speed.
All I can suggest is to give it a try in your kit and see what you think.
Any questions contact me 07568 108953 [email protected]
Hi,
Thanks for replying to Nepia's question Eddie, I missed reading the question about Aspen:001_rolleyes: (I must be slipping!!)
And I think you are right, Aspen's absence of aromatic hydrocarbons and ethanol (both volatile solvents) keep it a more stable product which maintains its vapour pressure across a wider temperature range making it far less susceptible to vaporisation and fuel lock than standard petrol.
The advantages of Aspen do, of course, come at a price, but a saw which wont start in the heat earns no money at all.
Barrie
Thanks; the only pump fuel I use is in the chipper - all saws, hedgetrimmers, leaf blower have been on Aspen for about 3 years now.
Jon
Jon
That's great to hear!
Thank you.
