  • Replies 36
If you use a resistor it Is a Fire source...... Get a rdx replacement relay off eBay the can be attenuated to give proper flash frequency, about 30 quid, if like me you have 4 or 5 trailers it is cheaper plus they still work with incandescent bulbs!
I've just ordered one! Thanks for that info:)
One of the problems with ballast resistors is they imitate a load, your putting on a 1 watt load using leds to save power, then defeating that objective by putting in a resistor load back up to 20w to fool the relay.
Sandworks has got it with the rdx relay.
heres the link that explains
RDX 4 Pin Flasher Relay LED & Trailer OK NO MORE Resistors LandRover Defender | eBay
For me LED's aren't about saving power, more the fact that they are zero maintenance, and never blow bulbs, a sealed unit won't corrode from road salt like incandescent ones do.
I want leds on because they are more focussed and you can leave your lights or hazards on without flattening or worrying about flattening your battery. I can leave my beacons on all day without worry.
...and also more and more new trailers and vehicles are now using leds as standard
Edited by Dean Lofthouse
I am just changing my trailer to all LED's.
The existing bypass relay works them fine but as they have less load the warning buzzer does not work which is now law to have.
I dont want the resistors (heat, power, cable size & later when the joints start to corrode the resistor will let the other bulbs flash due to a bad earth) so I am planning on changing the bypass replay for one that can do both LED & normal bulbs.
So far only found one for a sensible price eBay link
Just waiting for the seller to confirm that it will actually do what it says.
