new rigging kit
arbormonkey
I spent 1200 in Honey Bros the other week and that was rigging kit and aluminium gecko spikes, nothing wrong with your budget, unless you want GRCS, smartwinch etc.
I just got the Stein RC2001 bollard, about £230, DMM small impact block, ISC small block for redirects, or small rigging, rope isn't much £100 for 50m 14mm. Also got some 12mm for a pull/tag line, and a 30m length of 8mm for a fetching line for zipline pulley. Steel carabiners and 20mm width rigging slings.
The kits are ok too. I would have got the larger Stein RC3001 block if they had it in when I went. With your budget you could have the Stein RCW3001 with a little winch to lift the branch tips. See the Stein RCW3001 thread, about £750
What he said, except I'd use a pinto rig for redirects, and spend the difference on a half full of slings and biners for zipping stuff.
