10cms underground.
The regulation here is 50-70cm.
This was a home owner special.
A lightning cable in the MIDDLE of a garden.
Apparantly the tree once had lights installed in it.
Ty
I know what you are saying.
Simple visual checks usually give reason to start asking questions.
I did a job last week where I noticed an outside light on a detached garage. First question I asked was where the supply leaves the house to power the light, as it was the home owner had laid the supply just under the block paving we were about to dig up.
Job for the little reduced width grinder.
Through two narrow gates and a very tight corner!
Raised big old Laurel in a walled garden.
There it was...Gone!
Ready to be block paved and room for the extension to be built to what is a listed building.
Another very satisfied customer!:thumbup:
SG
How long did this one take bud?
I think I was on site for about an hour and a half for that one if I remember rightly. Raised ones like that are often a lot easier than they look as you take the top few inches of and there's not much below it other than small roots, soil and usually flint around here! Takes longer to set up and clean up than it does to grind the actual stump.:001_smile:
SG
Nice job, missing a bit off the air filter there aren't you?
How very observant of you!:blushing:
Yes mate, the hood or pre-cleaner part is off.
I keep meaning to get one and will look into it again.
Thank you for the reminder :thumbup:
SG
I couldn't obtain that bit so I bought a cheap flour sieve, cut out the gauze then attached it with a jubilee clip.
Quite 'pro' I thought...
Ty
Ah, that's what I will do with mine then!
SG
Sounds good to me
This is a Hawthorn stump last week, had been felled by another firm previously. Used a mix of proper stump shields and ply boards cut and cable tied to fold. Shop windows and carpark in close proximity. Done with a Rayco RG25HD which covers the work I do, I would highly recommend if you only want one machine. Will make a review of it on here for anyone who hasn't used one.
