Aspenarb, You do some amount of fixing lol.
Nothing that bad considering the amount of guys beating up the kit and motors Rowan. :001_rolleyes:
Transit belt tensioner went titsup, no noise or prior warning. :thumbdown:
Bob
That pretty rich coming from someone in your industry :lol:
Actually never thought of posting pictures of some of the mining mishaps here. Good idea Pete. :thumbup1:
main feed pipe to the valve block on the manitou blew open, not sure why the co that fitted the pipe put such a tight angle on the pipe ,
Same,main feed hose, on my hiab on a tight angle. So lorry is stil on the customers, until I get a new pipe tomorrow, then chatting up the fluid :(
No photos because it was 2130 by the time I got the house off.
Not so much broke as needing fixing, fitting this lot to the botex to improve performance from a pto high flow pump instead of off the spools, no instructions made it a bit fun.
Fitted and working fantastically really has improved the crane performance at low rpm on the tractor.
Had the same on the Mog for the timber trailer Gray, you just need to keep an eye on the tether. It gets interesting if they break loose :001_smile:
Bob
