Bad day for the tracked TW. Hydraulic pump bracket fell to bits and chewed up the belts , the starter has been playing about so had a look at that as well.
Mortice and tenon joint on a kin steel bracket what a POS.
Glued it together
Intermittent starter problem thats been getting worse, the lads have been beating it with a hammer.
Contacts all burnt out so its scrap.
Edited by aspenarb
  • Sad 1
Too many drag starts in the transit trying to get green waste out of the back made it smell funny according to the lads. :thumbdown:
I think its lost its newness
  • Sad 1
Transits never did have a long lived clutch, always thought they should have a gear below 1st for setting off with a arb load on ;-)
shame it was not welded up like that from day one.
Its not really the only design problem. The whole pump setup is about a foot long and is only bolted one end on the two holes.
After welding the bracket i made a stay/adjuster that runs from the engine to the pump. This should support it all a bit better
New starter turned up from Woodautos today , £90 instead of £160 from Kubota. Their part number STR 70073
All done and working :)
Bob
