Rattling Husq t540
Old Mill Tree Care
  • Replies 37
I have a rattling husq 266 sg. Heavy saw these days but just can't be without the heated handles. Any it rattles all the time especially on tick over. The cause is an aftermarket fuel filter made of metal rather than plastic rattling against inside of fuel tank, - took me ages to find the noise but not concerned now I know what it is. Will sort it next time I service. Could be a similar issue wirh yours. With engine stopped shake and roll the unit in all angles and positions to see if ya can track it down.
Just take the drum and clutch off the saw and Fire it up etc obviously being sensible and careful to eliminate the needle bearing and clutch units but my bet is it will be silent and as said its the clutch springs.
Did that two weeks ago and you're right, it was silent.
Clutch springs looked ok at a glance but I'll look again, carefully.
