Hi All,
I would like to buy a good quality chain sharpener, I currently out source this as I haven't mastered the art of sharpening by hand, however if theres a good enough sharpener on the market I would like to give it ago. Could anyone recommend a make/model please?
Thanks
  • Replies 23
I just use a cheapo Silverline one but have modified it with a speed control, it now grinds and barely produces any heat. As standard it used to fry the old crud around the tooth and discolour the red marker I use as the start point.
The sharpener now just grinds and no heat build up just takes slightly longer!
Sharpening chains is one of those jobs I hate - fine on a 2-3 strokes on each tooth on a dulled chain but one that has been toasted a bit:thumbdown: bloody monotonous job especially when the file stops biting in so well!
People knock grinders but they give a consistent finish and good results if used correctly.
well i use the the roller ones and a old jolly grinder same as the Oregon bench mount grinder and use both as much as each other and now would not be with out the grinder
I find these great.
I tried those roller guides 10 or 12 years ago and found the plastic rollers wear , dropping the file too low after a short while .
