But in theory having some of the friction at the skinny top bit is actually reducing the presure as it's reducing(slightly) the 2-1 caused by a pully system.
Correct me if I'm wrong but isn't that partly why David x man has been developing the tht 3 ring block thing? Also watched a good kiwi video with the porterwrap at the top of the tree for the very same reason...
  • Replies 88
Correct.
I sort of get that, just need to get my head round it. The rings would still be 2-1.
Those Kiwi boys are upside down remember.
All I know is I used to get shaken to buggery doing big lumps with topping down strops, but don't with blocks.
Isn't that because you were using 24mm poly prop and rapping it round the stem so sod all run in the system ;-)
Yes the rings would still cause a 2-1 affect but slightly less as some of the friction is at the top so let's call it more like 1.9-1:rolleyes::confused::what:
We rigged out a big fir with a fractured top last week. Heavy limbs 1ft x 30 ft many of them. I had a double ring high up around the main stem, and then ran the line to another single ring level with the first sling by about 3 foot out on a limb to direct the loads away from the stem and hang on the road side. With a block it would be 2 wraps or minimum one and a half on the 3001 bollard....but as it turned out the ground worker did everything with one wrap....which surprised me actually. But by spreading the friction in such a way was reassuring as i couldn't tell the extent of the fracture, and we were hanging some big limbs up there. In theory it might sound like a lot if fuss about nothing....but when you use them the benefits become much more apparent, as does the ease of which the ground worker can smoothly control the decending limbs and logs. With lighter stuff where with a block you might still need a half turn on a bollard, a set of hands with usually suffice.
  • 7 months later...
i am looking for uk supplier of tht and beast x rings, can only find shizll antal and arbpro, would like to but proper x rings to support it need some help!
does anyone splice themselves?
[ATTACH]190294[/ATTACH]i got these made up in a boating shop while on my hols In Devon £15 for the ring and £8 to get it spliced
that seems exceptionally fair price wise!
That my friend is a thing of beauty!
