You can clip a pulley to the small eye on your Cambium saver and then you can thread it through pulley then the big eye. Then you can retrieve like normal
I'd use a mallion rather than a carabiner though
  • Replies 33
the art rope guide is the tool for the job, its the most expensive but blows the competition away in every other way.
many people would advise against using karabiners at your primary anchor in case they rub against the tree, become damaged or roll open without you knowing or whilst you are so far away from them, they may well be out of site, like dan said a mallion nipped up with a short spanner is considered a better option by most
also many people would advise against using low melt point dyneema slings choked or prussic'd to rope/ hardware as the bridge of the choke/ knot is prone to failing under a much lower load than other anchorage devices
As tim tree began to allude to the standard micro pulleys that you get from most manufacturers will wear pretty quick (bush & axle wear) if used as a frequent anchor, but the art cocoon & art link are very hard wearing in this application, followed by the dmm pintos
splash out on an art ropeguide for Christmas and you wont regret it!
Whats the drawback with a Stine (other makes available) cambium saver. Which is essentially a sling with a ring at each end, all be it different sizes. Sometimes I feel like I need more friction not less!!!!!
Get a rope guide best investment I've made. If you get it to last five years it's costs you pennies per day and is everything you need in one package. The fiction free aspect is a joy compared to other devices
