pulley as a cambion saver
philip2011
Was watching a vid of someone on a rec climb saw him use a pulley as a friction cambion saver in his final anchor point is this possible and does any one use it if so what kind of pulley do you use and I am guessing you have to retrive it before you get out of the tree as I can see no way of retrieving it from the ground cheers Phil
  • Replies 33
