Rakers or cutters
50 members have voted
  1. 1. Rakers or cutters
    • Cutters First
      46
    • Rakers First
      4
not @ all you should be able to judge what needs taking off after a lot off yrs you will find it come on its own :001_smile:
I don't see the point myself, just do the cutters first, i can judge how much needs to come off before or after, i can also not damage the freshly sharpened cutters with a flat file.
I've not voted.
  • Replies 27
Cutters 1st, rakers last every time the only reason is thats the way I was taught and its now a habit. I always use guides (rollers) for sharpening, and a gauge for the depths. The depth gauge ensures consistency for each cutter, I know very few people who are so even-handed with filing to get it spot on every time, and the depth gauge will protect the freshly sharpened cutters. Sharpening free-hand is something i will only do as a touch up in the field, I always use guides in the workshop, and a vice for stability.
Cutters first, then rakers every time.
I do it by eye.
Following damage from metal or whatever and the chain needs resetting, I will use a depth gauge.
The key to fast cutting and low vibes however is the profile of the raker - make them rounded and smooth. :001_smile:
Cutters first' date=' then rakers every time.
The key to fast cutting and low vibes however is the [i']profile[/i] of the raker - make them rounded and smooth. :001_smile:
This is something I used to overlook, until someone pointed it out, just flattening the raker will make it bounce in the cut, causing vibes.
A great tip I learned for doing rakers, is simply put your combi spanners over a cutter and use it as a guide to file the adjacent raker. Easy!
I always sharpen before raker.
thats brilliant that! :001_smile:
