Don't get me started! So many people with stoves has got absolutely no idea how to use them.
Assuming you have a stove and it's fitted and all is in order, the first thing to get is a flue thermometer. I have no idea how people operate stoves without them - genuinely. I have a big stove and I know that it's running to spec when it's sitting at 450-550 degrees fahrenheit. Too much air and within just a few minutes it can get to 800. Too little air and a few minutes later it's down towards 300 and smoking. Flue thermometers are £6 from eBay and vital - perhaps all you proper firewood merchants out there could save yourself a lot of headaches and supply one free with every new customer's first batch of wood?
Also, a small fire can sometimes be counterproductive to economising on logs. Small fire equals less heat, less draw and therefore more air. A good, chock full firebox burning at the sweet spot of about 500 fahrenheit uses very little wood. I've loads of friends with stoves and a minority can use them properly. I had one chap say he didn't want wood too dry as it burned to quickly. Same guy who poked fun at me for filling up the stove rather than waiting an age for the three half wet logs to smoulder into life.
Anyway, we got a stove fan on Tuesday. It requires a minimum of 70c to spin and it has not stopped once in the past 5 days. Perhaps the answer for people who struggle to light fires is to get a stove that is nigh on impossible to put out?
mmm, do these here thermometers just sit on the flue?
My stove is a high efficiency German effort that does our hot water and heating and thus is insulated all round to help the efficiency - I can touch the side or top while it is roaring away - the only hot bit is the door.
The manufacturers have figured out how it works best so I just stick to their recommendations - pretty simple really
What ever the thermometer would tell me I have only one air control that only needs tweeking sometimes once the fire takes off, so not sure what use a thermometer would be.
That said I tend to be curious about what is happening so might just try one - 6 quid aint going to break the bank.
  • Replies 51
