Does anyone have pictures/info on any sleeper bridges they have built?
Got one to do in the next month or so before it gets too wet to get machines on site, but I have never done one before!
Thanks
Depends on the length of span, length of sleepers available and what you are bridging? Usually just make a frame which looks like this: TT either side, with two uprights and one sleeper across, then sleepers to span the distance between the frames.
Somebody round here rolled round bales into dried up stream
Bit of cheap shuttering
Then ready mix concrete
Instant bridge with arch
Cut bale up with chainsaw
I hope they had the sense to add some rebar to that too...
Thanks
I could have shown you pics of my sleeper bridge but it was converted into a raft all by itself the last time we had flash floods, it now lives a few farms away.
Bob:thumbdown:
Heres one I refurbed earlier in the year. What you need is two concrete plinths either end and some good, big rsj's, this one had 5 set in the concrete. I ripped off the old ones with the tractor and laid the new ones as we went so we could drive across to keep dropping sleepers. They are bolted up from underneath and there are two long angle irons either side with holes to bolt each sleeper with 12mm coach screws. I then did a maize of 3.15mm wire all round it and stapled down to help hold all together. There are 50 sleepers on this bridge, they were grade 1 hardwood from mcveighs, paid £16.80 each + vat and they are good ones. Quite a nice little job really, I reckon this would take 10t easy
altAuFAst23kOv9Y-JYOziwJUfurphQjjYzJ8YTH-Dly9VN_jpg.jpg.ce778f51c817aaab761a827588df0fa0.jpg
altApMfHo6gFJfESKNvfRkpTGw7iyPdnGQjt7Q4qslZB6Rs_jpg(1).jpg.25eec07d372c2e771824604ce240e06c.jpg
altAiMa3Bq7Dp0VCLcj6-oSTiV8ccbHUp0k95xZuP-EaoKf_jpg.jpg.8969e6ff5d0a650abbf56825cb329a02.jpg
altAi2jaRZTcr3Eb1EuryNe2CDLbBfZ0FMugeKsqpBJJFjD_jpg.jpg.40dd5b365c23ab780245d20dd0de6fbc.jpg
