  • Replies 102
My experience of the Tech lite bar is that after a short time they de laminate . Sugi for me !
Bent my one.
Sugi bars seem expensive but i've found on my 550 that its lasted 3x as long as the previous 13" bar on it.
Bent my one.
I used up a 24" chain on my 372 before fitting a new one I removed the bar to file off the burrs and flip it over but there weren't any burrs ! . Flipped it any ways . :001_smile:
Hi Rob,
Thank you for an informative post, Ive always considered Sugi one of the best bars available & seems an obvious choice when replacement is due.
N
I'd love to have a shop in the end with rows of gleaming bars in an orderly line.... but think this is sometime away as yet!
:biggrin:
:biggrin:
rob,whats the difference between the pro bar and the light type pro as they are near the same price ?
Yep as above post by TGB but there are x3 types of Sugi bars:
  • Laminated super light - tough laminated bars but they are not that light really - not as light as an oregon pro lite or some of the Stihl bars but def feel tougher and should last a lot longer
  • Pro solid - single piece steel bars - I think in terms of stiffness these are the best on the market compared to ALL other bar types (although no tests done to prove!). Using a 46" sugi pro solid on the 880 feels like using a normal chainsaw bar rather than something that flops a bit.
  • Light type bars - these are the pro solid bars - but with areas removed and filled with a tough resin. You do loose a smidge of the stiffness but weight saving is around 20% to 25% depending on bar. They also look the best -not that is matters but it is nice!
Vid on the light type bars here
They don't have to come with an adapter and in fact all the bars I have are made for the correct mount - but the next order will have a lot of multi mount bars running .325 .063 and 3/8 .063.
This means you can run them on both a Stihl or Husky + you only have to have 3/8 .063 chain if you run both types of saws. The adapter plates are getting better and really are simple to fit and remove (or will be!)
I did a vid on all the Sugi bars here which is informative if a bit boring!
:biggrin:
