hi people after a bit of advice regarding a log burner now i have a nice pile of logs seasoning thinking of happily away i am looking into getting a log burner im between 7-12 KW to heat the rest of the house as well my main bit of advice i a after is regarding the flue as it will be going up the inside of the existing chimney stack does my flue need to go the full length of the chimney or part way ? also does it need to be a rigid flue or can i use the flexible flue all advice and info welcome cheers phil :thumbup:
Burley 8kw would fit the bill . Burly stove are very simple to operate and very efficient . The 5 kw one I have is supposed to run at 89% efficiency . Your flue liner is normally a flexible stainless affair . There is a right and a wrong way up to fit them . Mine goes from the stove right to the cowel on the top of the chimny .
Second that. Burley 12kw Wakerley. Excellent stove 84% efficiency apparently. It absolutely pumps the heat out!
As the stove is over 5kw you would need to fit
An air vent
If the chimney stack is in good order
And does not leak when you do a smoke test
To check the integrity of the chimney
If it leaks or you want peace of mind
Fit a twin wall flexible liner with a pot hanging cowl
If you have any question s let me know
We fitted an 8kW Burley last year and would certainly recommend it.
If at all practical to do I would suggest forgetting the air vent and spend a few extra kit for the room seal kit on the stove.
If you're not familiar with the idea basically instead of bringing cold air from outside in to the room, you bring it directly in to the stove so no draughts and much greater efficiency.
Highly recommend The Champion Stove Company. I have three stoves from Martin and one more on order. Biggest is circa 20kw. Great stoves, built in Britain and very affordably priced.
Out of interest, can I ask how long you've had the stoves? And whether you have the glass door versions? They certainly look good value for money if they last and burn well...
Thanks.
Hi BIG J sorry mate I can not find the 20kw one on there site thanks Jon
I have an 18KW stove with water jacket that heats the house and the hot water. I fitted it 20+ years ago and my original stove split at the rear as I think I ran it too hard. The current stove has been in for the last 12 years with no issues. The system works on gravity. I have a smaller 8kw Firefox in the kitchen and a Woodwarm on order for my mother. This site is good for reviews from owners..Welcome to WhatStove stove review website - WhatStove.co.uk
Cheers
I think it makes sense, after all you don't find gas boilers that are not room sealed and I can see the business about draughts but claims for better efficiency?
Say you have a small room, 3m by 3m by 2.4m high, heated by a 5kW stove running flat out that stove will consume about 18m3 of air. The room has a volume slightly more than this but it also needs a couple of air changes an hour, so why not use the warm satle air in the stove before it leaves the building?
