Saw for the rhoddies
ballibeg
  • Replies 26
Not too keen on the 135. Pain to start. A lot of huskies seem like this. Always needing choke!
Good saw when running.
Mine never needs more than 3 pulls from cold and fast idle once warm it starts every time now I've set it up.
I think a 135 or 181 would be too small, not enough rev up and go. Keep the weight the same as far as possible but go bigger on the engine.
Especially if you're dong multiple cuts to cut all the tangles up, a lack of power will piss you off very quickly.
My MS250 is 3hp and 4.6kg. My MS181 is only 2hp and still 4.6kg.
If I was doing it day in day out I'd consider running an over length bar and a skip chain, maybe a 20-24" on a high revving 50cc saw. You can get some lightweight bars that run pico chain for milling applications. Light weight and good reach would be the thing for me.
