I only have up to 16" so I don't know about big stuff but I don't like to be able to lift the drive links clear of the bar so I tension it so they are still a bit covered when I lift the chain in the centre of the top of the bar.
I`m no expert by any means, but I agree with what peatff says!
  • Replies 34
and also i put a glove on to pull the chain back and forward to see if it ran freely and its a bit of a struggle to do with one hand but quite easy to do with 2 hands, does this mean that the chain is too tight?
Yes, very tight! You should be able to easily do it with only two fingers on the chain!
chain should be loose enough to feel smooth on turning rotating by hand but not so loose there is chain creep on idle.
Chain that is "creeping" on idle could well be caused by the idle adjustment beeing off. :wink:
My god! A forum full of professional saw users and nobody can agree on how to tension a chain!
From the husky 560 manual: "Raise the tip of the bar... tension the chain by turning the chain tensioning screw clockwise... The chain should be tensioned until it does not sag from the underside of the bar"
From the Stihl ms150t manual: "Hold the bar nose up... until the chain fits snugly against the underside of the bar... It must still be possible to pull the chain along the bar by hand..."
I was told a good gauge was to put the saw on a flat hard service and pull the chain with a gloved hand, the chain should turn easily and you should be able to drag the saw at the same time. If the chain spins and no saw movement too loose whole saw drags and no chain movement to tight!
Its a personal thing . I like them slightly looser than slightly too tight . I was told that if you strike an arc between the moon and alfacentorie the lift of the drive link should equal 2.37 times the bisected angle of an underdone sausage roll .
At last!
The correct answer.
:001_smile::biggrin::lol::lol::lol:
Surely if you can't tension the chain should you be using a power saw!! Put the saw in the shed and use an axe!:001_tt2:
Right I got the axe out the shed and the head is a bit loose, how do I check how tight it should be ?
