  • Replies 37
Must admit i always use an old stilh thing and am quite paticular in that will only use my own petrol.
Over the years seen all sorts, pouring into combi can till it looked the right colour, or 1 boss's son used to pour it straight into saw tank and just guesed the ammount???? mazingly don't think he ever seized 1, think he put a capfull in (no matter size of cap or tank of saw)
Do u all use the standard 50:1 mix???
Speaking to a mate who is a good 2 stroke mechanic and he runs everything on 25:1 says far esier on engine. He done a lot of work woth a large hire compamy so all the stone/stihl saws were getting a lot of abuse.
He said it doesn't coke it up to much and althou u wil go throu more plugs cheaper than an engine.
Wot's ur opinion's?? I've never ever heard of anyone doing it before
  DWestbrook said:
Yes i was being serious
I was thinking along the lines of the pumps being purposefully incorrect.
sure its an offence, that weights and measures would be quick to act on i imagine.
But does it happen?(or indeed has it?)
How much could it be short by and how long would they get away with it before it was noticed?
If at all a couple of percent? I know if I filled a combi can and it came up significantly short I would notice
If the pump did deliver short, it wouldn't be a tragedy from the saws point of view
  Phil71 said:
Come on grandad, you're worrying about nothing. Just use a stihl bottle with the measure at the top so you get the right mix!
Its Uncle not Grandad.
A.Trotter trees.
Fruit and Fir trees our speciality.
pal of mine uses 40:1 swears by it. recons its easier on the saws too. anyone else do that?
People do . Not a huge difference but I stick with 50: 1 . I have heard it said that running 40 : 1 makes them run leaner as there is less petrol in the mix and the slightly extra amount of oil can cause fouling and coking .....
  Wolfie said:
20L jerry cans from pump and 450ml of oil via measuring jug.
Sent from my iPad using Arbtalk
Same here
Sent from my GT-I9300 using Arbtalk mobile app
Read more
