  • Replies 148
That’s a different thing, its an exemption based on distance.
The exemption is for vehicles under 7.5t train weight, where it it's used for part of the drivers work AND where it's within 50k of base, it's not an exemption based soley on distance
If you tow a chipper you should use a tacho.
Your exemption for only carrying tools ect falls down if you carry chip or logs.
Therefore if you tow a chipper to site, fill the truck with chip or logs, and drive back towing the chipper you are breaking the law.
I don't know how I can make it any clearer really.
  • 11 months later...
I think if used for business (hire and reward) then the weight and commercial rules apply and one should have a tacho. Personal use then no issues unless overloaded on the towing weight of vehicle.
Agricultural/Forestry........ use if different.
Hence the reason that so many vehicles these times have no signs on in the hope of not being stopped.
You don't have to have a tachograph, the requirement is for keeping a record of the drivers hours, if the vehicle isn't fitted with a tachograph you can use a manual hours book.
