Hi Everyone,
Just a quick one, what would be your first buys when it comes to rigging ? I do not have any equipment as yet but would like to get ropes, slings, pulleys ect. makes and models would be a great help. nothing to fancy just to be able to lower limbs slowly and controlled.
Thank you
Start simple, get a 16mm rigging rope and a big krab and away you go old skool style.
Sent from my GT-I9300 using Arbtalk mobile app
I would say start with a micro rigging kit, less to go wrong till you get used to it
A sling, a steel biner, a pinto rig pulley and a bit of Sirius in 12 or 14mm and a friction device would be my choice.
Agreed.
If your not experienced in big rigging just start with the above.
I can recommend the Stein inverterwrap - Small, light, cheap but strong enough to handle fair size bits.
Sent from my iPad using Arbtalk
True, but why get into bad habits at such an early stage? Stick a pully on the steel krab and it will run a lot easier, not damage the rope, looks better and they are not exactly expensive or heavy.
Either a pinto rig or a swing cheek pulley.
14 mm bull rope , block , portawrap with sling and a pinto rig on a loopie.
you will be able to do almost everything with that setup , I'm really loving our pinto rigs for light rigging and redirects
I have a 14mm rope and that's done me really well, I've rigged some big piece of beech the it her day (6' 20-24" ) no problem. If I was starting out I'd get.....
14mm rope 50m
Small isc pulley
16mm dead eye sling
Couple of steel rigging caribiners
Couple of rigging slings
And either a flying capstain( whoopie sling required) or a bollard.
That'll cover most situations! Rigging kit is like climbing kit, the more you do the greater the amount of kit :P
Steve
