.......so,anyone inflate tyres with Nitrogen mix?...just curious.......
I use a Nitrogen mix - 78% nitrogen 20% Oxygen..............
Do you find your tyres are 2% under inflated? 😁😁
Sent from my Nexus 7 using Arbtalk mobile app
All tires on free nitrogen as that's what the fitters use. They're also quite happy to check pressures for you and top up if necessary. When I went in two tires had lost 2psi in two years, the others had lost nothing.
Nitrogen's a larger molecule than oxygen so doesn't diffuse through the tire walls as easily.
