I HAVE IT ON MY GARAGE SHELF SELDOM USED BUT HAD A DEAR OLD FRIEND VISIT AND HE NOTICE MY OLD CAN ON THE SHELF AND SAID OH NO TUT TUT YOU DON USE THAT STUFF DO YOU
WELL I DO WHEN ITS NEEDED GOT ME OUT OF LOADS OF FLAT BATTERYS BURNT OUT STARTERS A FEW TIMES WHATS YOUR VIEWS ?? OR HAS ANYONE USED AND ALTERNITIVE
  • Replies 25
Best off fixing the cause of hard starting, this stuff is a bit brutal, I would not use it unless the engine is destined for disposal & you are just trying to get the last bit of life from it.
I have a old petter ph1 on a liner bench saw and thats pants to start some days lungs going like bellows etc and just a whiff of the stuff and she,s pop pop popping away but i always try to start it normally first etc till i,am out,a puff lol
does anyone know the real reason why its frowned upon to use easystart as i,ve never buggered an engine using the stuff how could it ??
Edited by predator
Its very hard on engine's as its so volatile and causes a lot of stress. Its ok if used sparingly but is so easy to use too much.
Sent from my GT-I9300 using Arbtalk mobile app
Heard it said that it gums the rings up, hence the addiction
But I think the real problem is that where people are to heavy handed, it can cause a combination of hydraulic locking and/or backfiring. Used sparingly should be fine and always spray whilst engine is turning not before cranking
Can verify the addiction. We did once seem to wean a lister single cylinder diesel in a winget ( i think) dumper so it would hand crank up but the softer lads let it relapse. It does work however.
