As per title, happening more often now, the rollers will stop/freeze/jam on larger sections.
A quick reverse and it will carry on fine.
Fluids levels are good, greased etc
Where do i look next?
Thanks
  • Replies 37
Mine has done it from new 2007, never got to the bottom of it. New brain made any difference
Not what I wanted to hear.
Mine just seems to not have the power on the larger pieces. It will start to munch them, maybe do a foot, then the freeze.
check for any ware on the splines & roller box,big logs may be forcing the roller on to the casing if ther is excess waere ,on the ensd of each roller is a carreier fitted with a nylon bush if ther worn the roller drops ,
