  • Replies 43
You just need a proper splitting axe Steve; 3' is nothing - I regularly produce 5' billets with my X27 and you're twice my size and half my age!
your'e probably right mate but i cant afford one at the moment. what diameter logs are you splitting?
i'm currently making billets from 8"-12" logs.
how heavy is an elm mallet clive?
Elm all day long!! bit of dead hegerow stuff,,,had mine 20ys,,,(and yes I do use it lol)
Yep, that's what mine is. I dug out a stump about 6" across and use the root bole as the head, the very base of the stem thinned down as the handle.
I use mine for driving the froe (you should use a mallet on hardened metal such as an axe or froe, not a sledge). It has taken some serious beating and shows dents, but no sign of breakage after 3yrs abuse.
Alec
Alec
i've just learnt that the hard way as i noticed a crack around the wrap around part of the handle on my hatchet where it re attaches to the blade. i was using a large ball pien hammer.
can that be welded???
Yes, but it will need heat-treating again afterwards, otherwise it will probably crack again very quickly in the heat affected zone next to the weld.
Alec
For a 5' billet nothing thicker than 8-10" tops.
