How many hours do you expect to get from your chipper before it needs the fly wheel bearings doing? oh and what chipper it is would be good:thumbup:
The reason I ask is we are in a quandary as to which chipper to buy, im going to flip a coin soon between the 2 main options:001_tt2:
  • Replies 57
a good friend of mine has got a 190 (no turbo) and ive changed the main bearings every 400hrs and ive put uprated bearings in every time.
its not much of a job to do as long as you have got a decent set of spanners and a bit of know how. We only change them so oftern because they failed once and it was a night mare to et sorted.
My Vermeer Bc 150 has never needed a set of bearings and know its at 915hr
Regards
David
I'm just putting a set of bearings into a 1928 Greenmech that we have put 1350 hrs on, but had done a lot of work before I owned it (had a new clock fitted so unknown hours but had been a railway contractor's machine so unlikely to have had an easy life!). I grease them every 40 hrs religiously. In over 6000hrs of use across a number of Greenmech machines these are the first bearings I have fitted (but I am anal about greasing!).
Thats good to hear, I look after my gear as well so maybe to fact the green mech bearings are only 2/3 the size of the forst isnt such a big issue:confused1:
I ran greenmechs before the forst and I have never changed a bearing yet! Get a machine with proper sized greasable bearings, run shape blades and you won't have much of a problem.
Sent from my GT-I9300 using Arbtalk mobile app
Ooh I will have a machine with greasable bearings this year :thumbup1:
coming to the mainland to try the forst on mon:thumbup: the green mech was good but im not convinced it will last as long:confused1: both got nipples so all good
I think you are a bit hung up on the bearing issue.
Clearly its worthy of consideration but its only one factor in deciding which machine but don't let it be the deciding factor
