Hog roast
colwoodlandcare
  • Replies 29
I would go for a side & cook it over water lay a rack inside a large tray then stick a ltr of cider bay leafs then lay the pig on the tray score the pigs skin (grids) see above picture then cover in cider then rub in loads of salt cover with tin foil. then fill the tray with water cook on full wack for 2 hrs top up with water ( don't let water run low) cook for another few hrs remove tin foil turn heat back up to crackle the skin :)
Sent using Arbtalk Mobile App
