Would you advise against getting a stein cube then nifty
My stein cube poked a rod through the corner after about the third day.
However, that was three years ago and it hasn't got any worse.
Sent with my iPhone from me, to you!
My Stein cube also poked a hole through itself quite early, but too late to send back. Had it almost 2 years now and hasn't got worse but is not holding up anywhere near as good as some of the guys at the yard. I know my next cube purchase.
Jake:thumbup1:
I've just bought some skyline 1.8 mm seems quite good and i'm liking the lighter bag ( stein 8 oz ).
I've spliced a length of cheap red stuff on the ends so i can break it if its gets stuck.
I think next time i'll just cut a few strands to weaken it.
I've got a basic bag with 50mts of Marlow 2mm line. This is as good as I will need when throwing from the ground. However after struggling a bit recently to advance climbing line up through canopy as I'm climbing and getting the normal throw bag/kit tangled while I dangled I've improvised a bit and made this. Its about 10 metres of cheap nylon rope about 5mm diameter in a small cotton bag with a fishing weight 4 oz attached. The spherical weight is about 2cm across. Weighs next to nothing and can be carried with me. I think it will be a lot easier to make short advances to narrow crotches or to place a pull line higher. I realise lead shot has a slight safety issue but I wanted enough weight with a smaller size to reduce snagging etc. Will try not to brain myself.
I can think of nothing worse than having a throw line on my harness or using it in the tree. I can see myself boiling over just thinking about it. I'd rather throw a line from the ground,if I can't isolate the limb then srt it is.
J:thumbup1:
