polytunnel. Q.
Johny Walker
is ther such a thing as consertina type tunnel,so you can stack the bags then pull the tunnel over as you go,& could you put warm air fans in side without them melting the tunnel,just to get some warm air around the wood ,????
Northern polytunnels didn't used to be far from you Mr W .... LBS Colne will know
They do a rollover type tunnel for swimming pools, but from memory the cost was pretty eyewatering, Commercial horticultural tunnels are put up by the acre, the normal span is 8 metres I believe, you can drive a telehandler in them, but no insulation so heating is going to be of questionable benefit
dont want any thing that big its just to temp thing to get damp out of the logs ,
