  • Replies 22
I have one which I run off an 066 for use with milling. It is very handy for pulling butts out to where you can get at them, so long as you can get a good anchor point. It doesn't get as much use as I thought it would though as generally if you can drive up to the butt you don't need it, and if it's a long drag then it's one more big heavy piece of kit to lug so it's often easier to just work in the awkward location then have to take the winch in and out.
Alec
Iv'e got one. A good bit of kit. A bit of locktight on the nuts and its fine. It does say to put locktight on in the manual. Like someone else said, get rid of the wire rope, and buy some dynemma rope. Far better in my opinion.
Why would it affect clutch bearings?
Because the way it attaches. If the nuts loosen (which they done for fun when it was new) and you have the basic strop anchor, you end up putting some force on the saw aswell as the winch. The direct fitting onto the clutch drum is strong so the play goes to the weak point - the roller bearing
The mini guide bar fitting was ok but pissed oil down you're leg, even with oiler turned down
Could you not just empty the oil tank? or would that damage the pump?
I think the newer model does not need the bar attachment.
Though bout gettin one a while back. Got lots of windblown chestnut to deal wih, the thought of a tirfor makes my arm hurt! But so does tbe cost to the wallett!!!
Decisionz!
You don't need a mini guide bar with an inboard clutch. That is by far the best set-up
