  • Replies 26
I wouldn't think you'd get a tipper in t220 as that's a connect size. Do you not mean a 280?
The t350 is a 3.5t van. Which is where you get your tippers. T220 would have just enough room for your lunch
Sent using Arbtalk Mobile App
On board weighing systems are quite expensive. Especially if they are anywhere near accurate.
As has been mentioned previously, get a weigh bridge ticket. Do it regularly and keep the receipts you have with the load weight. That way, if you are stopped, you have a credible defence to show that you have regularly weighed the vehicle to check different types of waste and how full you are.
If you are a little over on the occasion you get pulled at least you have some defence. Even put markers on the inside of the greedy boards.
What if you were way over weight when stopped, would those tickets suggest you were well aware of being well over weight??
If vosa spot a tree surgeon thats not over weight they would think you have something more sinister to hide:biggrin:
You malign the industry, the bloke cold be on the way to his first job:laugh1::laugh1::laugh1:
If the springs are smiling your fine , if the springs are looking like a sad face your usually over weight haha
May we'll be cheaper to get something to weigh what your putting in rather than a system for your van
I'm suggesting, Huck, that if one has a recordable history of weighbridge tickets, and perhaps, load lines, that if one loads to the lines one may well have a defensible position.
It's axiomatic that if one is loaded over the lines one would be overweight and one would know it.
If someone is, as you say, way over weight they deserve to get pulled. I though we were discussing being a bit overweight.
